ENV: {PATH=C:\Program Files\PyroSim 2022\fds;C:\Program Files\PyroSim 2022\fds\mpi;C:\WINDOWS;C:\WINDOWS\system32, OMP_STACKSIZE=16M, OMP_NUM_THREADS=1, I_MPI_WAIT_MODE=1}
CMD: "C:\Program Files\PyroSim 2022\fds\runfds.exe" mpiexec.exe -localonly -n 32 fds.exe 23_05_19_Wood_A,E.fds
WDIR: C:\Users\user\Desktop\UOS 김시우\wood\23_05_19_Wood_A,E
Starting FDS ...
MPI Process 0 started on DESKTOP-LPEK26T
MPI Process 24 started on DESKTOP-LPEK26T
MPI Process 30 started on DESKTOP-LPEK26T
MPI Process 7 started on DESKTOP-LPEK26T
MPI Process 6 started on DESKTOP-LPEK26T
MPI Process 4 started on DESKTOP-LPEK26T
MPI Process 20 started on DESKTOP-LPEK26T
MPI Process 18 started on DESKTOP-LPEK26T
MPI Process 13 started on DESKTOP-LPEK26T
MPI Process 2 started on DESKTOP-LPEK26T
MPI Process 5 started on DESKTOP-LPEK26T
MPI Process 21 started on DESKTOP-LPEK26T
MPI Process 14 started on DESKTOP-LPEK26T
MPI Process 8 started on DESKTOP-LPEK26T
MPI Process 10 started on DESKTOP-LPEK26T
MPI Process 27 started on DESKTOP-LPEK26T
MPI Process 15 started on DESKTOP-LPEK26T
MPI Process 1 started on DESKTOP-LPEK26T
MPI Process 23 started on DESKTOP-LPEK26T
MPI Process 3 started on DESKTOP-LPEK26T
MPI Process 26 started on DESKTOP-LPEK26T
MPI Process 16 started on DESKTOP-LPEK26T
MPI Process 25 started on DESKTOP-LPEK26T
MPI Process 31 started on DESKTOP-LPEK26T
MPI Process 11 started on DESKTOP-LPEK26T
MPI Process 9 started on DESKTOP-LPEK26T
MPI Process 12 started on DESKTOP-LPEK26T
MPI Process 17 started on DESKTOP-LPEK26T
MPI Process 19 started on DESKTOP-LPEK26T
MPI Process 22 started on DESKTOP-LPEK26T
MPI Process 28 started on DESKTOP-LPEK26T
MPI Process 29 started on DESKTOP-LPEK26T
Reading FDS input file ...
WARNING: SPEC REAC_FUEL is not in the table of pre-defined species. Any unassigned SPEC variables in the input were assigned the properties of nitrogen.
WARNING: MATL YELLOW PINE, REAC 1. No product yields (NUs) set
ERROR: SURF Wood cannot have a REACting MATL and IGNITION_TEMPERATURE (CHID: 23_05_19_Wood_A,E)
ERROR: FDS was improperly set-up - FDS stopped (CHID: 23_05_19_Wood_A,E)
[runfds.exe] subprocess exit: 0
Files with pyrolysis applied will not be parsed, and files without pyrolysis will be parsed. How can I fix this?
If you answer in Russian, I can still interpret it. Please help me
Wood pine thermal degradation
Kim Si Woo
- asdfasdfasdf.png (14.06 КБ) 76916 просмотров
Re: Wood pine thermal degradation
Hello.
On Pyrolys tab you should select Byproducts tab and set fuel gas production: Also if you use pyrolis, you shouldn't set Ignition Temperature in Surface.
On English you can ask questions to Thunderhead directly: support@thunderheadeng.com
