Не запускаеться расчет FDS
Добавлено: 13 янв 2015, 00:10
Стал считать офп в месячной версии Пиросим, дошел до запуска расчета и расчет не запустился.
Выдает такое сообщение
Starting FDS: C:\Program Files\PyroSim 2014\fds64\fds.exe...
OpenMP thread 1 of 2 is running
OpenMP thread 2 of 2 is running
ERROR: OPEN, MIRROR, OR PERIODIC VENT 1 must be an exterior boundary. (CHID: Bloc_A)STOP: FDS was improperly set-up (CHID: Bloc_A)
Starting Smokeview: C:\Program Files\PyroSim 2014\fds64\smokeview.exe...
Smokeview 6.1.12 - Oct 1 2014
Version: 6.1.12
Smokeview (64 bit) Revision Number: 20604
Platform: WIN64 (Intel C/C++)
Build Date: Oct 1 2014
Smokeview path: C:\Program Files\PyroSim 2014\fds64\smokeview.exe
Smokezip path: C:\Program Files\PyroSim 2014\fds64\smokezip.exe*** Error: Smokeview file, Bloc_A.smv, not found
Texture directory path: C:\Program Files\PyroSim 2014\fds64\textures
Scratch directory: c: emp\
Initializing GlutGlut initialization completed
Initializing OpenGL
*** GPU smoke volume shader failed to load.
*** GPU 3d slice shader failed to load.
GPU shader initialization failed
OpenGL initialization completed
Processing object file: C:\Program Files\PyroSim 2014\fds64\objects.svo
Object file processing complete
*** Error: Smokeview file, Bloc_A.smv, not foundVersion: 6.1.12
Initializing Glut
Initializing OpenGL
GPU shader initiali
zation failed
Version: 6.1.12
Initializing OpenGL
Initializing Glut
Initializing OpenGL
GPU shader initiali
zation failed
